is there some sort of adjustment? Since there is no clutch lever you can't feather it into gear so when I click it into first it literally JUMPS into gear and every gear after.
85 250SX New to me!!
85 ATC 70 stock ~ TRADED
85 ATC 70 with 138cc Lifan
83 110 restored ~ sold
85 110 restored ~ sold
83 200x restored ~ sold
02 400ex ~~~SOLD
K&N filter
K&N jet kit
EHS Racing lid
Removed choke 42 pilot DJ146 main
HMF full exhaust
AC skids
Holeshot XCR rears
14t front sprocket
IMS Roll front bumper
Graydon Proline nerfs
Your idle speed must be set too high, lower it and you will not have any jump
1985 Honda 250r x2
1986 Honda 250r
1986 Honda 250sx
1985 Honda 250sx x2
1985 Honda 350x x2
1986 Honda 350x
1984 Honda 125m x4
1984 Honda atc 70
Yamaha tri zinger
Yamaha 4 zinger
Brap braaaap
Either the one way/centrifugal clutch is dragging or the manual clutch (shifter actuated) is mis-adjusted.
Like was stated above, make sure your idle isn't too high (which would cause your centrifugal clutch to drag).
If that is good, try adjusting your clutch.
Procedure to adjust the manual clutch (paraphrased from the service manual):
1. Loosen the adjusting screw lock nut
2. Slowly turn the slot headed screw counterclockwise until resistance is felt. Stop.
3. Turn the slot headed adjusting screw 1/4 turn clockwise
4. Tighten the locknut (hold the slot headed screw in position)
Try your shifting now.
- Frank
1984 200ES Big Red
1985 350X (x2)
1986 350X
1986 250SX
1984 Auto-X
1984 ATC70
1985 ATC70
My dads sx does that.. I just hold on the brake real good lol and pop her in.
Current Bike:
1985 Honda 350X
Bikes owned:
1984 Honda 200X
1982 Honda 250R
1985 Honda 350X x3
1985 Honda 250R x2
1985 Honda 500X
X2, to what wonderboy said, adjust your clutch. More than likely that's your issue.
My rides (click to view)
6/84 250sx(Original owner)
7/84 250sx
Click here to view my finished SX project thread
Click here to view my feedback thread
