Thread: How to take off 200es front tire off?
    Apr 2014
    Australia
    580
    Hey, I have a 200es and my front shocks have been weldered together, I have brought a new set of front shocks but I can't take the front tire off my 200es? Does the axle just come off? It's probably been sitting for 10 years? Is there a way to take the front tire off? Do I need to take shocks off first? Please help thanks
    6,811
    "Heat and beat" on the axle and hub , they like to get stuck at the brake hub so focus the heat their . Yes the axle is supposed to just slide out .
    Lots of penetrating fluid !
    Apr 2014
    Australia
    580
    Thanks, I was going to try heat but just wanted to ask, thanks for your help and quick response, appreciate it
    May 2009
    S.E. Michigan
    1,251
    A 200ES doesn't have the 4 bolt block that holds the one end of the axle (like a 350x or 250r). The fork lowers are just holes and the other side has nut... and most likely the whole works is siezed together nicely. The comment about beat and heat definitely applies. On mine, the only solution was a sawzall and ebay.
Name:	200es front end.JPG
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Chopsaw is offline Just Too Addicted Arm chair racerJust too addicted
    May 2013
    St. Louis
    505
    Heat and beat is a last resort . Remove the cotter pin .Remove the castle nut . Axle should slide out the right side of the bike . If it doesn't , thread the nut back on the axle just enough to be able to tap it lightly without the axle threads showing thru the nut , so striking the nut and not the axle threads . If it doesn't move , spray it with PB blaster and let it sit . Use a wrench on the other side of the axle , see if it will brake free . Spray it with more PB blaster . Give it time ,,, if it wont come out , then get heavy handed , do whats needed and buy more parts .
    Apr 2014
    Australia
    580
    Thanks Chopsaw, i did try to hit axle hard but still didnt move, ill try to lube it up more and see, if not ill get heat onto it.
