Thread: Chrome Rusting
    GSUwhiskers's Avatar
    GSUwhiskers is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2014
    Georgia
    168
    Chrome Rusting
    Anybody find an effective, non-scratch way to take rust off of chrome parts such as the front forks on a trike? Trying to polish up my project one part at a time.
    Mexico
    9,020
    Rust on chrome is indicative of a hole in the chrome that is exposing the steel under it which is prone to rusting very quickly when exposed to oxygen. The reason it rusts so easily is because of the processes used to clean the steel in preparation of the chroming. It is basically dry cold rolled steel which will rust when exposed to any amount of humidity.
    Besides the small red spot you can see on the chrome the steel is rusting under the chrome and so what you see is only a portion of what is under the chrome and spreading, or getting ready to.
    In the case of a set of forks that isn’t too far gone you can save them by rubbing them with extra fine steel wool and then protecting them with occasional wipes of oil, or a good metal polish. However, if the forks have high spots in the area that the seals pass over you need to knock them down to prevent damaging the seals. This would take some sanding with 2000# grit sand paper lubricated with light oil. It will dull the finish, but unless you have a show trike it shouldn’t be too noticeable. Remember to sand crossways and not in the direction that the forks move.
    Nov 2012
    Waldoboro, maine
    791
    I've used SOS pads on chrome rims before. Worked great! Use plenty of water.
    82 250r
    83 Big Red
    85 Auto-x
    If you've done business with me please leave me feedback
    http://www.3wheelerworld.com/showthr...ght=Bren_downe
    Jun 2009
    Leander TX
    2,217
    I've seen, but never tried, aluminum foil and water.
    Mexico
    9,020
    Quote Originally Posted by Bren_downe View Post
    Me too! On my Cragar SS wheels. Works great on the tires too! Forgot all about that.
