Thread: New 250sx
    Jul 2011
    Rushville, IN
    65
    New 250sx
    I just picked up an 85 250sx and its all new to me. I started with 2 82 185s' and it is a big change. I took off the carb (a pain) and cleaned it really well, but it seems like there is still a problem with the fuel supply. I also put on new fuel line. The choke cable was almost locked up in the carb but i got it out. I cleaned it as best I could (Is this a normal problem with the choke jet getting stuck?). The shifter sticks from time to time, but even with the shotty carb, it will still scoot, but not idle right. I'm looking for any tips on these bikes. I have wanted one for a while and finally found a steal, now I have to learn up on it. Thanks.
    1982 Honda ATC 185s x2
    1985 250sx
    Nov 2012
    Waldoboro, maine
    791
    Here's some reading for you;
    http://www.3wheelerworld.com/showthr...hlight=Flyingw
    FlyingW is like the ES-SX whisperer!
    Enjoy
    82 250r
    83 Big Red
    85 Auto-x
    If you've done business with me please leave me feedback
    http://www.3wheelerworld.com/showthr...ght=Bren_downe
    Feb 2013
    Senoia, Ga
    635
    Congrats on the new SX, they are a great trike. Use the search box and type 250 sx, there are tons of great threads on here pertaining to the SX. The shifter sticking could be the dreaded broken, or backed off shift pin. That's a pretty easy fix, if it turns out to be the issue.
    Btw, do you have any pics you could post up?
    Pacific NW
    4,255
    Dream machines.
    I like mine with flatter profile tires and Racks.
    Check the gear oil in the rear axle.
    It's only 3 POINT 3 oz so it wants every drop.
    click on:
    service manual
    for a real treat.
    Orig owners manuals are fun too.
    Jul 2011
    Rushville, IN
    65
    Thanks guy Ill be rolling into TF late tonight hopefully ill see you there and be able to get some hands on help!
    Maine
    463
    I have 2. They are nice machines..I never had trouble with the gears so cant help much there. Check the oil in the rear end and engine. Check your gas tank petcock it could be leaking or plugged if your tank is rusted inside..If not check your carb real good..
    Current Trikes
    2 1985 Honda 250sx
    1985 Big Red
    2 1983 YTM 200k's. 1 for parts.
    KLT 250 Prairie
    1982 Honda 185 - Waiting to be saved
    1985 125m Parts Machine
    Still on the hunt for a 1986 350x and 250r.
