Results 1 to 15 of 17
Thread: Can i see some videos of fast - built 200x's?
    Oct 2008
    Reedsport Oregon
    856
    hi, i have a built 200e motor in my fabbed x style chasis:
    uni clamp on filter, dg carb, ported head, webcam hi rise cam, tit valves and hd springs, 12:1 comp. and dg exhaust.
    it runs great, ok power overall but not impressive
    outran a stock 350x on hardpack all the way to a tie on top speed, the 350x will destroy it on any uphill though
    anyone have any hot setup 200x's?
    just seeing what tricks and parts work best
    long live the 200x!!
    6,802
    Big mikuni 28mm carburetor and megacycle 435 lift cam and you will be impressed lol .
    I'm not a big fan of web cams sorry !
    The Open Road
    4,736
    +1......I`m running a Keihin PWK 28 and a Megacycles 143-20 NS
    I`m more than pleased with both
    May 2013
    Brownsville, Tn.
    1,271
    Green Human has a 66mm stroker on here for sale that should wake it up.
    * Nicholson 500 Race Bike *
    Oct 2008
    Reedsport Oregon
    856
    yea im not impressed with the webcam either, didnt seem to do a whole lot other than move the powerband to higher rpm range, which is good for me in sand dunes, i wanted more low end so i put the wiseco 12;1 piston that did the trick, still it only dynos at 14hp to the wheels, stock was 12 to the wheels
    Oct 2006
    2,502
    Strap a go pro or your camera of choice to the guy you whooped on the 350x, then you will have a video of a fast built 200x
    Oct 2008
    Reedsport Oregon
    856
    we were both suprised my little 200 beat his mint and i mean MINT 86 350, he was extremely dissapointed, i just told him - jon you paid 1500$ for your 350x, ive got that alone just in my motor, i better have beat your 350!
    his 350x will stomp my 200 on anything but hardpack though, any hill, any sand etc.
    is 14hp about normal for a built 200 motor? seems low to me?
    Apr 2010
    Indian Falls, NY
    1,289
    Honda's factory rating was 18hp at the crank according to the manual, but we all tend to agree that was a bit high. 14 on a built motor? There's something wrong.
    Mar 2013
    Wausau, WI
    147
    14hp does seem kinda low after all that work
    Apr 2010
    Indian Falls, NY
    1,289
    I would think it would be somewhere around the low 20s at the crank honestly. So wheels probably like 16-17 sound like where it should be. Which would make sense since a stock 350X is about 20-22 at the wheels (27 crank) which would explain why he gets you in most tougher stuff. Maybe your carb isn't tuned right.
    Not that it really matters though, all that matters is that its faster than it was.
    Oct 2008
    Reedsport Oregon
    856
    yea im beginning to think the dg carb is a lemon for me, i had to dynotune it to get the correct jetting.
    14 was impressivley low! i figured at least 16hp? it runs great just is not what id expect from it
    it has more top speed and will crest banshee hill in 2nd gear instead of first now thats about it.
    a old rider said that the uni clamp on filter is not a good choice, and the stock airbox is alot better, i had to remove it to put the 200e's battery in
    it is a 200e motor not a x maybe this is why hp is lower?
    Oct 2013
    Wherever I May Roam
    3,757
    It actually could be a factor in the lower power at the rear wheels just because its an auto. But still, 14 hp with a ported 12:1 motor is not right bro.
    Are you positive the dyno was set up correctly? Do they have a dedicated set of dyno tires for consistency? Its super easy to manipulate the numbers on a dyno.
    Who did the porting? Did they flow the head? What were the numbers?
    If you really did beat his 350x, either his bike has issues, or the dyno numbers were wrong. Either way, no 14 hp 200x has ever beaten a great running 350x in a head to head race where both bikes made a clean run. The math just does not work.
    Maybe he let you win, and he's setting you up to take your money.
    Oct 2008
    Reedsport Oregon
    856
    the shop is called oregon coast powersports, they dyno all day every day, he did the porting as well.
    14hp sucks, he said it is what it is a stone age motor...
    it runs great so i dont know what id do to it from here?
    my 200 really did outrun jons 350x on the flats, if its any reason for my win, he had paddles i had 400ex tires, his 350x is bone stock absolutely mint cond, a 10 out of 10
    Michigan UP
    1,005
    Your motor started out at around 10.5 HP stock, you are running a 200e motor. So after the mods and considering you're running threw an auto tranny the 14 HP at the wheels is pretty good.
    Oct 2008
    Reedsport Oregon
    856
    Quote Originally Posted by briano View Post
    thats what i was thinking, i think a x motor would produce better #s. its ok i guess, i truly appreciate the e-start and auto clutch, and like that i can pull a trailer with its low range.
