Thread: Tri-z 250 overheating problem
    Nov 2012
    york england
    4
    Unhappy Tri-z 250 overheating problem
    Hi can any one help me I have had my quad rebored and new piston done
    By a bike mechanic ran it in slowly then went out on a track first time round it over heated
    Lost and soon as I put water in and start it it blows water out of expansion bottle
    Can any one help me please.
    Phil.
    Jun 2014
    South Paris
    11
    check the water pump. the propeller is just pressed on. they are known to strip, drill a hole and pin it.
    Xfile's Avatar
    Xfile is offline Just Too Addicted Arm chair racerJust too addicted
    Apr 2007
    Shiocton, Wisconsin
    700
    Tri-z's also have a thermostat like an automobile, the thermostat housing is located just above the cylinder head, bolted to the frame. If the thermostat fails and sticks shut it will cause the engine to overheat. I just remove the thermostat from my z's and run without it....billet thermostat delete kits pop up for sale on here from time to time also.
    Don't worry...just run watcha brung...
    Columbia
    5,131
    Blown head gasket, and a BAD case of horrible grammar.
    King Trikester is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2013
    Canada, B.C, FSJ
    435
    What temp should a z run at, I'm going to be firring mine up this weekend for the first time and I've got a fancy temp gun.
