Need some help on my 200X...
Built an auto-X with rebuilt 200S motor, I have and '83 185S carb using standard carb rebuild kit. I had 100 main jet and 40 idle jet (wouldn't idle was too rich). Adjusted up/down on the slide still seemed too rich. Then to decrease fuel... put in 98 main jet and 35 idle jet. My air fuel mixture screw I've adjusted from 1 3/4 turn (early 185S) to 2 1/4 for (later 200s) still getting same results. And my intake doesn't leak any air.
Other info: motor is .040" over new everything and I have a rebuilt supertrapp running 12 disks. I had less in 8 but later added more for noise. Obviously as exhaust is added jet needs to get bigger but its too rich going smaller on jets which tells me something ain't right. Casting looks fine on carb, has new intake gaskets and hooked to stock airbox with uni.
If anybody can pin point what I'm missing it would be appreciated
Brian
my wheelers:
1981 Honda 200 5-wheeler
1982 Honda 200 Hondapotomus
1982 Honda 185S
1982 Honda 250R
1984 Honda 200S
1985 Honda 200S
1985 Honda 200X
1985 Honda 200 auto-X
