Thread: Honda Atc 200X 200S 185S carb jet question
    Jan 2011
    New London, Wisconsin
    119
    Need some help on my 200X...
    Built an auto-X with rebuilt 200S motor, I have and '83 185S carb using standard carb rebuild kit. I had 100 main jet and 40 idle jet (wouldn't idle was too rich). Adjusted up/down on the slide still seemed too rich. Then to decrease fuel... put in 98 main jet and 35 idle jet. My air fuel mixture screw I've adjusted from 1 3/4 turn (early 185S) to 2 1/4 for (later 200s) still getting same results. And my intake doesn't leak any air.
    Other info: motor is .040" over new everything and I have a rebuilt supertrapp running 12 disks. I had less in 8 but later added more for noise. Obviously as exhaust is added jet needs to get bigger but its too rich going smaller on jets which tells me something ain't right. Casting looks fine on carb, has new intake gaskets and hooked to stock airbox with uni.
    If anybody can pin point what I'm missing it would be appreciated
    Brian
    my wheelers:
    1981 Honda 200 5-wheeler
    1982 Honda 200 Hondapotomus
    1982 Honda 185S
    1982 Honda 250R
    1984 Honda 200S
    1985 Honda 200S
    1985 Honda 200X
    1985 Honda 200 auto-X
    Willamstown PA
    5,824
    I ran a 110 and a 35 on my 40 over motor on a 200x, it needed it with a full exhaust.
    Jan 2011
    119
    Oh ok. Guess I'll try that tomorrow then, thanks. And for the slide pin... you still left it in the middle?
    6,811
    Did you replace the needle and seat when you rebuilt the carburetor ?
    Also how's the spark ? A weak stator wont deliver enough spark to the plug and make it seem like a carb issue .
    Willamstown PA
    5,824
    I always leave slides in the middle, they get to tricky if you go up or down.
    Jan 2011
    119
    Yes needle/seat are also new. Spark is good, new NGK dR8EA (I think) one that all the 185/200s uses. Plug wire and coil are also brand new.
    Jan 2011
    119
    Ok good to know. Ya I agree, you're pretty much guess at that point.
