Results 1 to 15 of 16
Thread: run away 2 stroke!!!
    Sep 2013
    Coggon, IA
    113
    My 82 250r runs away when I start it. I can't find any air leaks, the reeds look fine and the carb seems ok.
    Nov 2012
    Waldoboro, maine
    791
    It's either an air leak or it's not getting enough fuel.
    Check fuel flow from tank and check float level.
    Look up "leak down testers" and make one.
    Maybe your crank seals? I'm not sure if that would make it rev out like that…
    82 250r
    83 Big Red
    85 Auto-x
    If you've done business with me please leave me feedback
    http://www.3wheelerworld.com/showthr...ght=Bren_downe
    Hampton, Virginia, C.S.A.
    2,664
    did you make sure your cable and slide arent binding up?
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    May 2003
    Houston, Texas
    2,409
    It could be a bunch of things:
    - carb slide stuck
    - air leak
    - not getting enough fuel
    - throttle cable binding somewhere so its pulling the slide
    - too small a pilot jet (causing a lean condition)
    - Yes a dry side crank seal leak (ignition side)
    Its scary as hell when they do that. I had a KTM 500 do this...scary when a big two stroke is reving like that and you can't stop it!!
    The throttle cable on mine was binding up!
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    devore,ca
    1,016
    The slide in the carb is in backwards ?.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Oct 2013
    Wherever I May Roam
    3,757
    Did you recently mess with it?
    How long has it been doing this?
    Did it start acting up suddenly, or slowly over time?
    What do you mean the carb seems ok?
    Check for fuel blockages from the tank all the way to the intake.
    Sep 2013
    Coggon, IA
    113
    I rebuilt the engine. It didn't do it the first few times I started it. It just kept getting worse every time I started it. I am getting fuel in the carb. It will run slow enough if the choke is on. I'm going to spray some WD 40 at it to see if I can find an air leak.
    emmie357's Avatar
    emmie357 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2013
    Upstate NY
    214
    Did you do a leak down test after rebuilding?
    I would start by pulling the carb and checking that the slide goes down all the way... if it does, then do a leak down test.
    84 YTM200E "yamahauler"
    85 YTM200
    85 KXT250 Tecate
    Sep 2013
    Coggon, IA
    113
    A leak down test would tell me if I have a leak. But I don't have the equipment to do it.
    emmie357's Avatar
    Jul 2013
    Upstate NY
    214
    You can build one cheap, do a search and you will get a ton of ideas/materials to use.
    In the long run it's great to have one on hand. And there is really no substitute.
    85 YTM200
    85 KXT250 Tecate
    Oct 2013
    Wherever I May Roam
    3,757
    revving but runs slow enough when choked, its probably lean.
    Apr 2013
    snyder texas
    456
    had same thing after rebuild on polaris 250 trailboss, somehow crank seals did not hold up replaced them again and cured it leakdown test is in order
    you know whats right therefore you know what is expected
    NEPA
    7,049
    I think WD will just make it shiny. ? I've never used that method,I do use Ether. But you need to do a real leakdown test,as suggested many times lol
    Feb 2012
    sc
    19
    Pull the bowl check the pilot and float valve especially if you running ethanol fuel probably orange goo in the float bowl limiting gas flow.if not then x2 on the air leak,should be easy problem to solve with right tools..
    ATC 431R
    Sep 2013
    Coggon, IA
    113
    I traded it for 2 200x's.
