Results 1 to 11 of 11
Thread: speed question
    Winnipeg
    211
    speed question
    My buddies 82 185S is faster than my 1984 200ES.. is this normal?
    off the line my 200 jumps ahead of his 185.. but once we hit 5th.. he blows by me!
    We figure its cause I weigh 40 pounds more plus the 200ES is 80 pounds heavier.
    Dec 2011
    Grand Rapids, MI.
    679
    The weight difference is definitely part of it, plenty of little things play effect too like what size and kind of tires you are using. Also shaft drive loses you some top end speed.
    1986 KLT 185
    1984 200S
    9,019
    This is the same buddy that can do wheelies when you can't right? I'm starting to see a pattern here. The issues may just be the connection between the thumb on your right hand and the things dangling from your groin.
    May 2008
    Northwestern Ontario, Canada
    552
    Weight is a BIG factor. You only have a few cc's on him + the shaft gearing is way different than a 185 chain drive. The 200es is designed as a ute as well. Two completed different animals.
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
    Winnipeg
    211
    yeah he has small tires and im running the super wide big tires..
    Blossvale NY
    4,563
    There's nothing wrong with your Big Red. On it's best day with a tail wind, I think my '84 MIGHT hit 45mph or so....
    The 200es was not designed for speed and sport riding....
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    The Open Road
    4,736
    185s are faster than a 200....and has a better cam.
    More displacement does not equal faster. Plenty of small motors can stomp a mudhole into its larger brethren. Way to many factors to give bigger pistons all the credit
    Winnipeg
    211
    Yeah I can hit 46 MPH..
    he can do 50!
    BUT I consider mine pretty good for weight and size diff
    ZacH_GrifF's Avatar
    ZacH_GrifF is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2011
    Pearl, MS
    405
    My 185s would hit 50 before I regeared it. 200e has a lower gear ratio to take advantage of torque because it's a utility bike. 185s is a lighter sportier bike so they put a higher gear to give it more top end.
    1. 83 185s: (the money pit) xr200 cam, 200cc cylinder, 10.25:1 piston, 83 250r front end, 450r hubs, full suspension
    2. 85 Big Red 250es: in pieces
    3. 85 200m
    4. 00 Polaris Magnum 325 2x4: stays broke
    5. 02 Yamaha Wolverine 350 4x4: trail bike
    Oct 2008
    Reedsport Oregon
    856
    get a kawasaki 185 and rip him a new one
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Just do a xr200 top end swap you will leave him then.
    3. 85 200m
