Results 1 to 10 of 10
Thread: Carlial at489 24-8-11 on a 350x??
    Ok i bought a new douglas centerline rim''for a 85r'' today and the tire i put it on and the tire rubs the right side of my forks really bad.Is the off set on a r different then a x or is the off set on the new rim different than stock. thanx im out 80 bucks for the tire :oops: .
    yater is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2003
    Tyler, Texas
    672
    what kind of tire is it? I hope you didn't put that 489 up front :shock:
    Newfoundland
    5,280
    Why wouldn't you use an AT489 up front? I don't see anything wrong with them for a front tire.
    Dec 2002
    749
    Im not sure why it wouldnt work, and I cant really tell you whether or not the rims are the same. Are forks at the same spot in the triple trees?
    3WheelsForever / Virgil
    TrikeFest 03, 04, 05, 06, 07
    1985 Honda ATC350X - TF2015 Project
    YZ426 Hybrid Trike - On the back burner
    Jun 2003
    South of Rochester, NY
    3,471
    Do you have both axle spacers on?? Do you have the axle screwed in all the way?
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Took the tire back the rim had a diff off set thanx
    May 2002
    Cortland, NY
    1,195
    Don't use one of those muddin tires on the front of a trike! I still don't get what people are thinking when I see that since those tires weigh a ton and are hidious looking. Get either the stock othus pro V or a front max.
    http://photos.yahoo.com/dynofox250 (TF 03 pic's)
    Trikes: Restored '86 ATC 250r, original and mint '83 185s
    Quad: '86 TRX 250r
    Sled: Rev X 800ho mod
    Bike: '00 ZRX 1100
    TF '03 and '05 Survivor
    Apr 2003
    546
    not gonna say anything about tire choice, because it is just that a choice...run whatever tire you like.....as for rubbing the fork....you got problems.....as far as i know(and i am sure someone will tell us if i am wrong) there is no OFFSET on a front rim...either your axle is loose or you are missing a spacer..or the forks are not in the trees correctly!!!
    1985 ATC 250R
    2006 TRX450ER
    RIDE RED...IS THERE ANYTHING ELSE??????????
    Roanoke, VA
    4,038
    Why not use the 489's....I love them. My brother had one on his R and I think 86250RZ from this site has one too. IMO, they hook up better than most other tires out there.
    [20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
    Quote Originally Posted by md1985250r
    Its a after market douglas rim and it has a off set of a ich to the right
