Keihin main jets: small round, large round, either??
I was looking to get replacement Keihin main jets for a 07 KFX700, in case mine are in bad shape and I am seeing two types: the Keihin small round part#99101-116, and large round part#99101-393. The dimensions are a little bit different. Has anyone used these? Can either of these be used or must it be a specific one? Thanks.
The application should be specific for the carb model. My guess is that the 700 came with two different models of carbs? Maybe thats why they list two types of jets. I would say NOT to use jets of a different dimension than the correct type. I get all my Keihin jets from JetsRus. They are genuine keihin and shipping was fast. Maybe they can tell you exactly which version you should be using.
Since I had not taken the carbs apart, I was not able to confirm the dimensions. I wanted to have them on hand before doing so. And thanks, I will check with them to see what they tell me.
If you call your local Kawi dealer and give them your VIN, maybe they can tell you which carb yours came with?
Rob
//ArrowChat Integreation Code
