White smoke pours out the exuast it smeels like oil but after thirty seconds of running it stops?
Probably condensation in the cylinder, or possibly oil leaking past the valve seals (althought that should be blue smoke if valve seales are the case). In any case I wouldn't worry about it, anything old is gonna smoke when it starts up cold.
1986 ATC 250R(for sale), 1963 AceCraft boat w/40HP Evinrude, 1981 Arctic Cat El Tigre' 440 L/C, 1992 GMC Safari Van.
It could be the valve guides.
1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
1984 Honda 200ES
198? Yamaha YT60 Tri-Zinger
TrikeFest '04 & '07 Survivor
I believe your R is water cooled, right? If so, white smoke is generally coolant or water burning. I would check your fluid level and see if it is diminishing. the most common areas for a head gasket to blow is between the waterjacket and the cyclinder, thus causing the symptom you described.
If your coolant level is constant, then it may be condensation.
Good luck
Psycho
he said it was an x, so... its prolly not 2 stroke.
My Rides
Yamaha 225 DR For Sale Soon
Yamaha 200E
Honda 110 Need parts? PM me! They're cheap!
Trikes are fun, trikes are fast. They make everyday a pure blast!
What is the clicking coming from the top of the head
sounds like ya need a valve adjustment![]()
~JUST RIDE~
While your X is still cold, I think oil is getting past the rings. Once it warms up, it quits...
[20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
