Results 1 to 10 of 10
Thread: 85 200x starting issues.
    Sep 2013
    Coggon, IA
    113
    I just got an 85 200x. Sometimes it will start ok. Sometimes it won't start at all. I started it up today and let it run a while. It ran for a few minutes then died.
    Sep 2013
    Coggon, IA
    113
    I pulled the spark plug out and it was wet. I cleaned it up and it tried to start a couple of times. I opened the throttle a little bit and it started right up. So it must be running a little rich. Which way do I turn the screw to lean it out a little?
    Apr 2013
    VT
    147
    To lean it out, turn the screw in, a little at a time.
    1986 ATC250R
    1986 ATC200X
    1985 ATC200X
    Sep 2013
    Coggon, IA
    113
    Ok thanks.
    Apr 2008
    NW, IND.
    842
    Did it sputter or pop when it died or did it just quit? If it just quit it sounds like a sticky jet/run out of fuel. Try running some Seafoam thru it. Fuel/ethanol these days suk.
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Des Moines, IA
    1,303
    Well, the spark plug is likely to be wet when it's not starting. I wouldn't think that means it's running rich. I think you need to test compression. Oh, and since you just got it, make sure the right plug is in there. My 200s had always been a bit hard starting, and I had it for years when I finally figured out it had the wrong plug installed! Starts easily on the first pull without the choke now.
    God knows they're not looking to make any effort to do anything, never mind move their foot to shift. If there was something that dispensed Cheetos every time they shifted that might be a different story. Welcome to America, where the biggest is best and even fat people who are too lazy to shift can climb a mountain.
    Sep 2013
    Coggon, IA
    113
    What plug does it takes and where is the mixture screw?
    Slidell, LA
    4,738
    Mixture screw is underneath towards the intake side on the bottom. You can use the following plugs, but I stick with NGK.
    NGK - DR8ES-L
    Champion - RA6YC
    Sep 2013
    Coggon, IA
    113
    Well it looks like the compression is probably a little low. Thats probably the problem.
    Des Moines, IA
    1,303
    Quote Originally Posted by 3>4 View Post
    Yeah, I had an '85 just like that for a few years. You had to open the throttle just so before it would start. Problem is it belonged to a buddy who abandoned it at my place, so it wasn't really mine to spend the time fixing. Finally tracked him down and got it back to him last summer. I see you're in Iowa. Maybe you bought the same machine!
    Probably time for a top-end rebuild.
