Results 1 to 13 of 13
Thread: happy 350x owner
    Jun 2014
    Oregon,Medford
    67
    happy 350x owner
    hello everyone new to the forum and looking for help finding or repairing my frame for my new 350x. the frame is really twisted and has been broke on the upright and re welded poorly any help would be much appreciated
ID:	196549   Click image for larger version.
    Jun 2013
    Southern Indiana, United States
    140
    i will sell you a frame
    350cc's of Pure Adrenalin'
    '85 350x
    '85 Big Red 250
    Mar 2013
    Central PA
    2,362
    Look into the TPC gusset kit. I personally have no clue if you should find a new frame or not, but for future use you should gusset your frame. Do you have access to a welder and experience doing so? It's fairly easy from what I hear.
    North Dakota
    1,643
    Very very common right there. Mine is the same way. One day I will buy a titled frame and gusset it up and put it together that way. But for now it works!
    Jun 2014
    Oregon,Medford
    67
    i am confident to weld myself what i am lacking is the know how to straighten a sub frame.look how the chain is closer to the grab bar on one side then the disc is on the other
    Sarnia, Ontario, Canada
    3,415
    A good donor frame is just the ticket..a gusset kit, blast and powder.
    A crap welding job and that thing is looking pretty tweaked on top of it..probably does circles to the left all by itself!! Certainly wouldn't be trying any shenanigans on that machine!!
    Hope you didn't over pay...
    http://detroit.craigslist.org/wyn/snw/4493207876.html
    Just the thing..but a bit far for you to go pickup!!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    devore,ca
    1,042
    It looks like your frame is trashed to me. At least from the pic. They are tough to straiten, I've tryied. Time to start looking for a replacement. Most all the 85X frames will be cracked, no biggie if you can weld, but they need to be gusseted in a few areas.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Jun 2014
    IN USA
    10
    Is it just the 350x frames or should I be worried about my 250r. Hope I'm not sounding stupid still a noob here
    84 250R
    Jun 2009
    Leander TX
    2,217
    350X much more than 250R.
    I sent the frame from my 85 to TPC for the gusset install. The frame was not cracked but was twisted around the rear subframe. TPC fixed it for me.
    Shipping was a pain and not cheap.
    For my 86 I bought the TPC kit and worked with a guy locally to install. The frame was OK going in.
    Jun 2014
    Oregon,Medford
    67
    i paid 500$ for the 350x knowing the frame was tweaked.i want a second frame to restore from.The bike actually rides just fine the way it is bent. I took it out today for about two hours and it sure felt good its been almost a year since my last trike ride.
    devore,ca
    1,042
    My '85x was cracked or broken in 7 places, but was strait. My '86x is not cracked but is twisted in the neck/backbone area and the rear subframe was bent, not bad but bad enough to bug the crap out of me. MY point being that both years are weak. The 85's would crack so Honda beefed up those areas for 86. Then they just bent before they cracked. The 250r frames are a much better design and are much stronger.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
    Oct 2013
    Wherever I May Roam
    3,757
    The weld you are showing isn't that bad it just has some buildup. If that's the only repair, its really not that bad because there are a lot of damaged 350x frames out there. Make sure its not the swingarm that's bent as well. Pressure and heat will bend your frame back in to shape.
    Jun 2014
    Oregon,Medford
    67
    thanks for the input everyone. Its definitely the frame that's bent not the swingarm. Like i said the bike rides fine it just bugs me I want a second frame anyway and i can ride it like it is for the time being.
