Results 16 to 30 of 35
Thread: 200x spark problems
    Apr 2013
    snyder texas
    456
    How are you checking for spark? Plug against head? Try unscrewing plug cap see if spark from plug wire to ground make sure ignition coil is grounded good and kill switch is disconnected or is working correctly
    you know whats right therefore you know what is expected
    Apr 2014
    Edmond, KS
    2,591
    A repair manual will tell you how to check your electric system. Where did you buy your cdi? I've bought cheap cdis and coils off of ebay and even thought they looked like the original, they had different ohms readings. I now always check them as soon as I get them. Just a suggestion.
    Feb 2014
    Victoria,Australia
    878
    here are some pics if you need any more close ups i can get them!! also is there meant to be oil under the stator cover because some bikes have oil in there and some don't and im not sure if it should or not...
    Attached Thumbnails Attached Thumbnails DSCN3786.JPG   DSCN3787.JPG   DSCN3788.JPG   DSCN3789.JPG   DSCN3790.JPG   DSCN3791.JPG
    73 atc 70
    84 ytm 200ern
    79 atc 70
    ytm 225 dr
    atc 90
    80 atc 110
    klt 250A
    84 atc 200es
    85 atc 250es
    Jan 2011
    Greene,Ia
    688
    did you unplug the kill switch and try?
    2006 Yamaha Raptor 700
    2004 Kawasaki KFX700 V Force
    1985 Suzuki LT230GE(wifes toy)
    1985 Honda ATC 70
    1979 Honda ATC 70 (daughters toy)
    Feb 2014
    Victoria,Australia
    878
    Quote Originally Posted by SteveCZ28 View Post
    I did but I will double check again to make sure!!
    73 atc 70
    84 ytm 200ern
    79 atc 70
    ytm 225 dr
    atc 90
    80 atc 110
    klt 250A
    84 atc 200es
    85 atc 250es
    Feb 2014
    Victoria,Australia
    878
    Unplugged the kill switch still no change dead as a door nail!!
    73 atc 70
    84 ytm 200ern
    79 atc 70
    ytm 225 dr
    atc 90
    80 atc 110
    klt 250A
    84 atc 200es
    85 atc 250es
    Jan 2011
    Greene,Ia
    688
    do you have power coming out of the stator? do you have power going to the coil? did you unscrew the sparkplug cap from the coil wire and test for spark there? sometimes the cap looks like its on, but isnt screwed into the wire, so no spark.
    with that much oil in there, id clean all the surfaces in there. clean the coil trigger. that rides on the outside of the flywheel, that rides on the external magnet of the flywheel.
    1985 Honda ATC 70
    Feb 2014
    Victoria,Australia
    878
    Ok when I put the multimeter on it does get power but i have no idea if its enough! and i have not checked the coil...I have not pulled the cap off but I have tried 3 different coil and none made a difference but I will pull the cap off and try it...and I will clean the flywheel and get back here!!
    73 atc 70
    84 ytm 200ern
    79 atc 70
    ytm 225 dr
    atc 90
    80 atc 110
    klt 250A
    84 atc 200es
    85 atc 250es
    Jan 2011
    Greene,Ia
    688
    id put a test light on the wires going to the coil, and see if you have spark to the coil
    1985 Honda ATC 70
    Feb 2014
    Victoria,Australia
    878
    Ok i will do that and see!!
    73 atc 70
    84 ytm 200ern
    79 atc 70
    ytm 225 dr
    atc 90
    80 atc 110
    klt 250A
    84 atc 200es
    85 atc 250es
    Feb 2014
    Victoria,Australia
    878
    I put a test light on ad kicked it over I have power from the yellow wire but none from the red and black!!
    73 atc 70
    84 ytm 200ern
    79 atc 70
    ytm 225 dr
    atc 90
    80 atc 110
    klt 250A
    84 atc 200es
    85 atc 250es
    Jan 2011
    Greene,Ia
    688
    upon further inspection of your pictures. pictures 2 and 4 both show the same green wires. are they spliced there or something? it looks like 1 or 2 wires might just be hanging and not attached?? idk what those would be for
    and red/black, is that the same wire coming from the new piece you soldered in? if so is it even making contact??
    1985 Honda ATC 70
    Feb 2014
    Victoria,Australia
    878
    Ok for some reason the new 'thing' i soldered doesn't work so I put the old one in and it actually lights up the light now but beyond that I don't know where to head to now!!
    73 atc 70
    84 ytm 200ern
    79 atc 70
    ytm 225 dr
    atc 90
    80 atc 110
    klt 250A
    84 atc 200es
    85 atc 250es
    Jan 2014
    La
    1,062
    You might want to inspect your spark advancer. I know when my 200m wasn't giving me spark I checked and cripple the checked everything but it. After I got a new advanced low and behold I had spark.
  15. #30
    Feb 2014
    Victoria,Australia
    878
    Quote Originally Posted by 86125m View Post
    How would I check it the manual just says to check the gap??
    73 atc 70
    84 ytm 200ern
    79 atc 70
    ytm 225 dr
    atc 90
    80 atc 110
    klt 250A
    84 atc 200es
    85 atc 250es
