my 85 250r is running so terrible i dont want to even ride it. i put an aftermarket bills pipe on it and its jetted perfect the plug is golden brown. The carb was leaking out the overflow until i took it apart and cleaned it. the only time it wants to run good is when im in 5th or 6th gear tapped. low end it has no power. it has good compression. im wondering if maybe one of the reeds broke? maybe the float is out of adjustment? would like some input from others on my situation.
