Thread: Good front master cylinder/caliper swaps?
    Sep 2011
    New Castle, PA
    1,134
    Question Good front master cylinder/caliper swaps?
    Hi again.
    I'm looking for a good swap for my front master cylinder and/or caliper for my 200x, maybe someone has some experience.
    I've considered the chinese repros on eBay but to me they are a last resort, Honda first . I could rebuild the M/C and caliper with kits, but theyre just plain worn out after 31 years. I already have a CR85 M/C and caliper swap in the back.
    Thanks to those who reply in advance
    Gone:
    1,641
    I used a nice used YFZ 450 on my trike.It was clean for around $50.It is a bigger than your stocker.Braided brake lines help a lot.Does your caliper still slide?If so I would lube it up and clean it out with a new seal.
    Sep 2011
    New Castle, PA
    1,134
    Quote Originally Posted by jays375 View Post
    Did you replace both the MC and the caliper? My caliper does not move much. My front brakes worked when I started my rebuild, but they are super tired
    Gone:
    The Open Road
    4,727
    I have a late model kx80 rear caliper on my front and my front master is an XR250 front mc... Just because I had a spare and it bolted right up.
    1,641
    No my caliper was good.The braided brake line is key.Your old rubber line swells to much when pressure is applied.
