Neighbor brought me a little 2001 Polaris scrambler 90. they brought it to 3 different guys to try diagnosing it and ended up spending an arm and leg replacing parts without results. So I got it and began testing. heres what ive found out. Voltage checks came up as over 90 volts from stator, 6 volts trigger, over 90 input into cdi, about 10 volts coming out. no voltage at ignition coil. guessing the cdi is bad? Any more suggestions for testing?
