Results 1 to 7 of 7
Thread: 86 350x crashed, now steers crooked help
    t-3 is offline New to the board Arm chair racerNew to the board
    Oct 2009
    southern illinois
    18
    My brother was down at st joe state park and flipped my 86 350x on some whoop d whoops. he is ok except for a broken collar bone, that sucks. bike didn't fare to well either got the handlebar straightened up but now when riding down the road when riding straight handlebars are off center. any suggestions on adjustments to fix this or would one think that frame, tubes, or triple tree bent?
    stillhunter's Avatar
    stillhunter is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2010
    Port Perry Ontario Canada
    180
    Loosen off your tripples a bit and front axle clamp try to straighten out the wheel. Usualy works. Alot of the time you will hear it pop back straight as your loosening
    85 250sx..The Big sexy
    84 200s....Crazygirl
    R.J.M.'s Avatar
    R.J.M. is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2013
    Missouri
    181
    U said your handle bars are off center......may also try a different set that is straight, maybe just the bars are out of whack
    1986 250R
    1985 Tri-Z
    1986 200X (wife's)
    Honda 70's-x4 (kids)
    1982 250R project
    I always loosen the upper clamp stem nut as well.
    Just have to relax it all and then back and forth with each bolt/nut etc a few times. Stems bend too......
    Mexico
    9,018
    Good point. There's a lot to properly aligning forks and axles, especially the inverts. Amazing what 1/16" of misalignment does to the action, not to mention the added wear.
    You may have a bent fork(s).
    Aug 2012
    Ct
    67
    Ditto what fabs said they bend right below bottom triple...drop the fork and feel for a kink.
