Results 1 to 3 of 3
Thread: 86 200x clunking. Need help!!!
    honda3's Avatar
    honda3 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2012
    maine
    232
    Ok so I have an 86 200x. I boughtn a motor off eBay and it sat in my shed for almost a Year. I put it in and it ran awesome. No weird noises or anything. I rode it home last night from a friends house, it was running awesome, parked it and went inside. I woke up this morning and went outside to start it and ride it. I kicked on it and for a split second it started and it was clunking awfully. It then stalled out and seized. So I checked the oil. It's good. Took out the spark plug. It looks good. So with the spark plug out I put it in gear and pushed it around, it slowly unfreed itself. It now kicks over. I put the spark plug back in and started it. It was making the same awful noises. Sounds like its in the top end. Doesn't t seem to be the crank. I'm thinking timing chain jump or valves are messed up. Help!!!
    My 3 Wheelers
    1986 atc 200x(garage queen)
    1985 Honda 250sx
    1985 Honda Big Red
    1985 honda atc 70 breast cancer build
    1985 yamaha tri-z 250
    1985 Yamaha yt 60
    1985 yamaha yt 60
    1984 Honda Atc 70:
    1984 Honda atc 70
    1984 Yamaha Yt 60
    1983 Suzuki alt 50
    1983 atc 200x
    1983 atc 185s
    1982 yamaha yt175
    1982 atc 200e rider
    1980 honda 185(all original)
    1978 Honda atc 90
    May 2013
    ontario
    Maybe the valve hitting the piston? Does the bike seem to have the same compression as what it did before?
    honda3's Avatar
    Jun 2012
    maine
    232
    I think the valve is hitting the piston also. Has same compression but at one point it's hard to turn over. Pretty sure it's valve hitting the piston. Wat causes that? Timing chain jump?
    My 3 Wheelers
    1985 Honda 250sx
    1985 Honda Big Red
    1985 Yamaha yt 60
    1985 yamaha yt 60
    1984 Honda Atc 70:
    1984 Honda atc 70
    1984 Yamaha Yt 60
    1983 Suzuki alt 50
    1983 atc 200x
    1983 atc 185s
    1982 yamaha yt175
    1982 atc 200e rider
    1978 Honda atc 90
