i have an 85 3500 citation ski doo it always starts perfect [img] and has tons of power but always screws up her plug put a new one in and get a ride and she'll do it again suggestions?
ps.i make sure th egas is mixed right[/img]
is it smoking more than a normal sled?
sounds like maybe:
getting too much:
oil in the mix
gas in th mix
rings might be worn out
bore job might be needed
i would check the plug make sure it is the right heat range for the motor,
maybe try 1 hotter then if that didn't help i would,
if it has a auto oil injector i would disconnect it from working and try a tank full of mix gas(2 stroke oil/high test gas ratio should be listed on the sled somewhere around the oil tank)and see if that helps if it does there is a prob with the injector system.
if that didn't help
check the top end
piston/rings
and jug bore.
1982 250r it will run again, new rings,razors,stator!!!(UGLY)
1985 200x runs on race fuel or alky ONLY!
western new york riders check out:
http://groups.yahoo.com/group/wny3wheelernuts/
thanx but i got it fixed it was a wire arking out
Thats why you ride Polaris lol j/k![]()
TF 07,08,09,10,11,12,13,14!
