Results 1 to 15 of 16
Thread: 1986 350x electric start trx350 interchange?
    t-3 is offline New to the board Arm chair racerNew to the board
    Oct 2009
    southern illinois
    18
    Just had a great time riding my 350x this weekend at st joe st park, however I am walking with a bit of a limp from kick starting my rig. hate to leave it running when we stop with the air cooling and hot weather but man those things are hard to kick over. I have an 84 250r also and it takes half the effort to start, so I usually ride it more! Had some thinking time on my way home and was wanting to ask this question, will an electric start off of a 86-87 trx350 work on my 86 350x. im thinking front cover, flywheel and starter. any thoughts or suggestions. did some reading and I could go with a goki kit but im trying to keep an oem look.
    wolfspider's Avatar
    wolfspider is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    HARROGATE, ENGLAND
    376
    no its a non starter the 86-87 trx is shaft drive so the side cover is totally different.
    HONDA ATC250ESJ 1988
    HONDA 250R `85 restored SOLD
    HONDA ATC 350X `86 restored SOLD
    HONDA ATC 250ES `87 SOLD
    YAMAHA YZ100 `80 project
    HONDA ATC350X `85 PROJECT FINISHED
    Van down by the river
    3,874
    You might want to make sure the decompression is hooked up correctly. Mine does not start that hard. Also your pilot jet could be a little clogged.
    R.I.P. John Swinehart
    Epic Mikfest 17
    86 200x
    85 250sx
    85 big red
    85 atc 70
    Feb 2006
    EC
    1,607
    Yea, the decompression cable could be maladjusted, makes em harder to start and they're a bear to get right.
    Goki starter kits are still popping up on Ebay, and Goki might still be making them, I'm not sure. They come with very thorough instructions and all the hardware, plus a press to get the pinion gear onto your flywheel. It takes a couple hours to install but worth the time.
    The only con is the start button. It mounts to the bar clamps & looks kind of silly, my plan is to wire mine(and the lights) to a 400EX swtch.
    Baltimore---Charm City, or Harm City? Ask Pat.....
    May 2013
    Henderson, Tx.
    977
    Like everyone has said, check, and adjust, your decomp cable accordingly. I'm running an 11:1 bigbore and it's not hard to kick over. Okay, maybe not THAT hard, lol. But, once I get it up on TDC, it's just a matter of standing on the kicker until she starts to roll over, then it's a good kick and it's off to the races.
    Oct 2009
    southern illinois
    18
    ThanKs For The Input Ill Check Out Those Adjustments For Sure then
    May 2011
    eden,ny
    3,481
    x10 on the decomp cable and x2 on starting on tdc (compression stroke) I have a mod 70 that will rip the pull cord right out of your hand if you just grab and pull. On TDC it is almost effortless to pull and starts right up.
    May 2013
    Henderson, Tx.
    977
    Quote Originally Posted by just ben View Post
    Funny you mention that, because I love watching people grab a pull starter and yank it like it's a lawn mower, or weed eater! Hilarious!!
    devore,ca
    1,016
    Getting the kick starter to the right position is critical to starting an X. Also is getting the decomp adjusted right. I just put a Goki on one of my x's. It will not work at all unless you get the decompression figured out. The starter button that comes with the Goki is usless. Get an early 400ex switch. It looks just like a 350x light switch but has a starter button.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Sep 2012
    Trafalgar, Indiana
    70
    I definitely recommend checking the decompression cable. I went ahead and got the Goki since the 350x is the girlfriends ride and she's great at killing it with the back tires in a ditch where it's hard to get a good kick in.
    trikes:
    1982 Honda ATC110
    1984 Yamaha 200el Yamahauler
    1985 Honda ATC250r
    1985 Honda ATC350X
    truck:
    1951 Chevrolet 3600
    1950 Chevrolet 6400
    Dracut Mass
    307
    not trying to thread jack but can any one point me in the right direction on how to adjust the decompression cable? i can't find any thing in the service manual so if any one has any tips, tricks or a link that i could click on and read i would VERY MUCH APPRECIATE any help thank you
    devore,ca
    1,016
    First check to make sure its even functional. Allot of them get broken when folks don't install the right side cover properly after changing the clutch. Push the kick starter down to see if you have movement on the lever at the side cover. Then -what I do- is adjust the cable a little at a time, then start the trike. If it is too tight you will see the lever on the head going up and down, or you may just hear it clicking as if it is barely hitting. Back it off a bit until you don't have any movement or clicking sound while the engine is running. You should be real close at this point.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Also, check your valve lash. If the valves are to tight they can be a bear to start.
    TF 07,08,09,10,11,12,13,14!
    Dracut Mass
    307
    Thanks to both of you. It doesnt move. Doh! There goes 43$ wasted on the cable and bracket lol.
    devore,ca
    1,016
    They will still start fine without the decomp if the valves are adjusted right, the carb is dialed in and you learn the "sweet spot" on the kick starter position.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
