Page 4 of 8 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 46 to 60 of 112
Thread: '86 200x Conversion E-START,REVERSE,AUTO CLUTCH
  1. #46
    JustEnough's Avatar
    JustEnough is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    Elk Grove, CA
    333
    Saw some exhaust blowing by the front of the engine in the video. Maybe it needs a copper exhaust washer between the header and head.
  2. #47
    Aug 2007
    Montana
    857
    What is going on is the header pipe is not square to the gasket "Fresh Air In"........I hope the smoke issue will go away with the new seal! Time will tell !! She is a Super Fast STARTER!!! I HOPE NOTHING IS REALL WRONG INSIDE
    DO the Best With What you got !
    My Feed back :cool
  3. #48
    I've had pipes that do this because every bend,length and mounting isn't perfect in every application.
    I heat them up with oxy/acet and bang them around with a big rubber mallet (with my boot), to set it into where IT WANTS to go to seal up correctly......
  4. #49
    Aug 2007
    Montana
    857
    On this pipe I'm going to cut off the last 9'' of the pipe and flip it 180 and re-weld !! this will move the pipe out and around the frame! it's a huge pipe ! this should work
    My Feed back :cool
  5. #50
    Aug 2007
    Montana
    857
    I took this "X" for a brief ride down the drive and back she is going todo well
    My Feed back :cool
  6. #51
    Aug 2007
    Montana
    857
    still a bit to soon for a full ride report ! but Reverse is way cool
    My Feed back :cool
  7. #52
    Aug 2007
    Montana
    857
ID:	201574Click image for larger version.
ID:	201575Click image for larger version.
    A friend gave me a pr. of 350x scoops a few years ago they were cracked but workable,,, and they found a new home ...just a few little mods and they did good!!!
    My Feed back :cool
  8. #53
    I am absolutely amazed that this is a relatively easy swap ( No discredit to your work though!! )
    At LEAST 3 guys said, "It cannot fit, it will not work etc etc" and I figured they knew what was up.
    But here's to you that didn't probably even read those posts and got it done!! What a fine lightweight 86 200X you have now in the same family as the 250SX which is quite a bit heavier......
    WELL DONE!!!!!
  9. #54
    May 2013
    Henderson, Tx.
    977
    I had an 86 200sx. GREAT little bike! Sat for years with water in the engine before I got it. Still ran like a Honda after a couple oil changes. Super cool little build, Duece!!!
  10. #55
    Nov 2013
    Hamilton Ontario canada
    41
    Good job dude, looks awesome.
    I love that seat man, if you get an original seat, I'll buy that one from yea.
  11. #56
    Oct 2013
    Wherever I May Roam
    3,757
    WELL DONE!!!!!
    Some guys just have a way of making it look easy. Ol deuce is obviously one of us.
    Fantastic result.
  12. #57
    Aug 2007
    Montana
    857
    Fantastic result.
    Thanks !!!! This is what I love todo
    My Feed back :cool
  13. #58
    Mar 2011
    weatherford,ok
    140
    nice job and a well built trike
  14. #59
    Aug 2007
    Montana
    857
    Quote Originally Posted by kazander View Post
    Thanks Man!!!!!
    My Feed back :cool
  15. #60
    Apr 2014
    Louisiana
    53
    Man this is awesome! Y'alls ingenuity is inspiring!
