Results 1 to 2 of 2
Thread: wheeler stopped running?
    Jul 2014
    Upper Michigan
    6
    So I was out for a ride, honda 200s 3 wheeler. Ran good as always, stopped to talk with someone and it stopped running. I can't get it to start again. Have it in my garage now, in the dark I can see that the spark plug has spark, is it good enough I don't know. As long as I have spark I guess. Where do I go from there, gas? How do I know if its getting gas? I guess the plug would be wet or smell? Should I pull the carb off and clean it? This machine is rather on the poor side, I got it for free and its not worth putting much into. But if I can get it going for cheap great. Thanks.
    cap's Avatar
    cap is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2014
    Nevada
    163
    You could pull the air filter and prime the carb with a squirt of gas or starting fluid. If it fires up and then stops its not getting gas through the carb. Check the fuel tank petcock and clean the carb.
