Results 1 to 15 of 23
Thread: 300sx questions
    Apr 2013
    Vermont
    67
    300sx questions
    I'm planing on trading my 86 rm 250 for a 85 250sx this weekend. The guy selling the sx says it has the head, cam, and piston from a 300ex, a full cobra exhaust, barnett clutch, and a 350x front end. The guy owns a small engine repair shop so I figure it should be a decent running rig. I was just wondering if anyone else has tried the 300 top end conversion and does it really make much of a difference?
    Feb 2014
    Victoria,Australia
    878
    ohh look at the bike in the background it's one of them 2wd rokon's very cool!!
    73 atc 70
    84 ytm 200ern
    79 atc 70
    ytm 225 dr
    atc 90
    80 atc 110
    klt 250A
    84 atc 200es
    85 atc 250es
    Apr 2013
    Vermont
    67
    Just picked it up and took her for a spin. She's not perfect but she loves life. The 350x front end is a little weird cause it sits up so high, I can pick up the front end in every gear real easy, and it keeps up with my neighbor's crf 230 no problem. I took a look at the identification tag thing on the front and it says 1/85 on it does that mean it's the first one made in 85 or something? Also there is some fluid leaking out of the top of the forks, anyone know what could be causing this?
ID:	197663   Click image for larger version.
    Feb 2014
    Victoria,Australia
    878
    1/85 is the first month of 85
    73 atc 70
    84 ytm 200ern
    79 atc 70
    ytm 225 dr
    atc 90
    80 atc 110
    klt 250A
    84 atc 200es
    85 atc 250es
    Apr 2013
    Vermont
    67
    Ok thanks, I figured it was something like that
    Jun 2009
    Leander TX
    2,217
    Quote Originally Posted by beastybaconman View Post
    ... Also there is some fluid leaking out of the top of the forks, anyone know what could be causing this?
    The bashed schrader valve on the fork cap.
    Apr 2013
    Vermont
    67
    I thought it looked a little rough, I just wanted to make sure it wasnt something else, are those valves pretty easy to replace?
    Austin, Massachusetts
    1,591
    your forks look a bit bent. also, i'm no 350x expert, but i think its supposed to be a leading front axel. i think. not sure. i think your forks are backwards. your wheelbase is weird... any help from someone that knows??
    Wubba Lubba Dub Dub!!!!!
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    85 Yama 225DX - The Rental!
    150cc Piranha powered 70
    110cc Lifan 70
    82 70
    83 ALT 50 Trail Buddy
    88 Yamaha BW 80
    84 z50
    Apr 2013
    Vermont
    67
    Thanks for mentioning that I looked at some pictures of 350x's and it looks like my forks are on backwards. Thats probably why it's so easy to wheelie
    Apr 2013
    Vermont
    67
    Just turned the forks around rides a lot better, they are bent a little is there any easy way to straighten them up or am I better off just getting new ones?
    Xfile's Avatar
    Xfile is offline Just Too Addicted Arm chair racerJust too addicted
    Apr 2007
    Shiocton, Wisconsin
    700
    Bring them to a machine shop with a good press...a shop in my area straightens them for $30 a pair.
    Don't worry...just run watcha brung...
    Apr 2013
    Vermont
    67
    Alright I'll try one of the machine shops around here, thanks for the reply
    Apr 2013
    Vermont
    67
    I was just messing with my front wheel to get it centered more and I found that the axle bolt has different threads than the threads on the fork. Because of this, where it threads into the fork it's a little beat up. From what I can tell it is the front wheel from a 350x so I don't know why it isn't fitting, anyone know what could be going on? Maybe the previous owners used an axle bolt off a different rig or something?
ID:	197687   Click image for larger version.
    Jan 2014
    Massachusetts USA
    782
    Just to let you know, a 300ex top end is identical to a 250x top end, except it has 282cc cast into it instead. The 300 gets it extra cc's from the stroke. I actually didn't realize that 300ex tops fit onto 250 Sx cases, but if that's what you have, I think you're still only at 250cc.
    1985 Tri-Z 250
    1985 ATC250R
    Apr 2013
    Vermont
    67
    I don't know if it is the whole top end off the 300, the way the guy was talking it was just the head and cam but not the cylinder. And if it did have the cylinder off the 300 with the longer stroke wouldn't that make it have less power?
