Hello everyone- I just picked up a '84 ATC 200S that the recoil starter does not work. I pulled it off and tore it down to find that the piece of steel that the "dogs" or "teeth" pivot on and turn-out when you pull the recoil handle, had broke the spot welds off the main body of the "pulley" that the cord wraps around. I attempted to weld it back on last night, but I think my plug holes are too small and the weld keeps "grabbing" the piece of steel and not the "pulley". If I can't get this to hold, I need a replacement piece.
I've looked on e-bay and seen recoil rebuild "kits" going for $80~$100, but this machine is a low hour unit, so everyting inside the recoild looks new, except for the broken spot welds. Does anyone know if someone, or some shop sells individual parts from the "kit"? All I really need is the "pulley" for I can reuse everything else.
Any input would be appreciated. Likewise, if this has been covered, please point me at the post, for I tried searching buy several different key words and found nothing.
