Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Thread: 86 tri-z power valve questions
    9,018
    Quote Originally Posted by Stephon_xr500 View Post
    I must have knocked the vacuum line off the cylinder when I adjusted the clutch cable.
    This line was off when I started looking at it today. It runs again but still feels very flat in the top end.
    DUDE! That hose will come off again as soon as the temperature drops a few degrees. Get a new hose and leave some slack in it.
    Nov 2012
    Phoenix
    135
    I think the backfire may have been from the carb "running out of gas" since the pump had no vacuum.
    I'm bringing the 80's back!
    85' 200x - 84' 185s - 85' 125m - 83' xr500
    Nov 2012
    Phoenix
    135
    New hose is on the list of parts I need for it, along with a clutch cable
    Nov 2012
    Phoenix
    135
    So I swapped the 320 main jet for a 420 main jet. It feels alittle better but still feels like it Boggs down after 1/4 throttle twist I'm gonna have to go bigger still
    Nov 2012
    Phoenix
    135
    I managed to get the clutch cable to work for a lap around my neighborhood (I think I'm missing a clip that holds it on to the "U" fitting on the motor case)
    So I plug chopped; I got it nice and warmed up, got it into 6th wide open Throttle, clutch killswitch coast to a stop.
ID:	198145Click image for larger version.
