Thread: Malossi 70cc kit for trizinger?
    Jun 2014
    Rockvegas Ma
    17
    I saw this kit searching on here for mods and was wondering does it just swap out or is there other stuff that needs to be done like rejeting or timing or anything else, and how difficult is it to do? I was also wondering about clutch springs would heavier ones add to bottom end power what is there advantage, are they worth doing? As you can tell I'm not engine savey My trizinger doesn't seem to want to climb hills unless I'm going full bore up them and unfortunately where we ride is very hilly terrain. Any advice is greatly appriciated
    rayatc84's Avatar
    rayatc84 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2010
    France
    194
    I have this kit on 2 Zingers and it's just a simple swap.
    The only modification is a shorter sparkplug if you also have the high compression head.
    Outside of engines with holes that stink, there is no salvation...
    My feedback thread: here!
    Want to see overseas 3wheelers? http://www.passion-atc.com of course!
    YT60 Tri-Zinger, YT70 Tri-Zinger modified, '84 ATC 70, '82 ATC 110, '82 250R, '82 250R modified, '84 250R, '84 480R in build, '85 310R, '86 250R, '87 250ES BigRed, '84 FL250 Odyssey, '85 FL350 Odyssey
    Jun 2014
    Rockvegas Ma
    17
    Cool ,would stock exhaust effect it much as after I buy the kit I'll have to wait on upgrading it ? I'm also planning on swapping the reeds , do you have any thoughts on the clutch springs?
    rayatc84's Avatar
    Aug 2010
    France
    194
    Both mines have Malossi kit + high compression head.
    First has DG exhaust pipe and the second has stock exhaust.
    But both have stock carb, jetting, air box, air filter and clutch without any issue till now.
    The one with DG pipe has more power and faster revving.
