Thread: 350x loose axle
    Oct 2011
    Southwest MN
    8
    350x loose axle
    I just replaced the rear axle bearings on my 86 350x. The axle still moves back and fourth.. Any suggestions as to what I'm doing wrong?
    f76's Avatar
    f76 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    South Dakota
    323
    Is the axle nut assembly torqued properly?
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
    Sarnia, Ontario, Canada
    3,415
    Take it apart again and recheck your work..
    I'm quite sure the answer will become clear to you.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    May 2009
    S.E. Michigan
    1,251
    Just keep in mind how the rear axle is supposed to tighten up into the carrier.
    You are going to tighten the axle nut up to pull all the following parts together into solid contact:
    - The sprocket hub on the axle
    - The inner bearing race of the left bearing
    - The spacer tube between the bearings
    - The inner bearing race of the right bearing
    - The threaded inner sleeve portion of the rear axle nut
    - The large outer axle nut
    - The collar around the axle
    - The snap ring in the groove on the axle
    All these parts are in direct solid contact when the axle nut is tightened correctly. You can see that the process starts and ends with something attached firmly to the axle. The key is to make sure there is no slop between each item in the list. If your axle still moves back and forth, there must be daylight somewhere in the path.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
