How do you paint the plastic on a 3-wheeler? Is there a best kind of paint to get? ? I got this great trike 8) , but its solid black, I don't like the color x . Any advice?
I know there is plastic paint called krylon fusion or something! Some guys on here have used it but i dont know how good it works.
Matt
1980 ATC 70 Needs Restoration
1985 ATC 250es Fully Refurbed
1986 ATC 350x Mint Original
Krylon works good. try to find the undustrial krylon. i used it on my atc200, got some cat yellow off my boss, works great. designed for paintin the big cat engines. great scratch resistance and fast dry time. krylon is the best. hope this helps. p.s., take the plastics off! and use short, quick strokes and a few coats. this works the best and turns out great. peace out, tony.
Wheels:::::::::::::::::::::
1983 Yamaha Tri-Moto 200E twist throttle and factory 909 grips!
Thanks, I'll give it a shot. appreciate your help. Krylon is available.
Originally Posted by 4marine
Go ahead and try the Krylon. But if your looking for better longer lasting results you shoud get some automotive paint with a hardner and a flex agent - the same stuff they paint all the plastic car bumpers with.
Aerosol spray paint simply cannot take the abuse of trees and rocks being shot at it but Auto paint stands up to highway rocks bouncing off of it.
I tried the krylon fusion for $4.00 a can and it said scratch free after one week dries in an hour or something.NOPE!!! I waited one week after painting my front fender black, picked it up and scratched it with my finger and that crap came right off.GARBAGE JUNK ETC!!! So, you should go with the auto flex type paint from what I understand but I have not tried it before.Good luck!!
Auto body plastic bumper action. You need that kind of action. Dudeman has it right about that flex action
So what is this flex agent called? Is it already in the automotive paint?
Current Rides:
'87 Tecate 3
'84 Tecate 3
When you buy your paint and thinner you just get some flex agent with it that mixes with the type of paint your using.Originally Posted by JMiller
Your gonna have to just walk in to an auto body paint and parts supplier and explain what your trying to do. They will normally mix up just a quart or half gallon for you but colors are more cash.
thanks for all the replies and discussion folks, I think I'm on the right track. called a few auto paint shops and almost all of them told me to come on in they would fix me up. the flex needed is apparently is pretty common to them, car bumpers etc. We'll see. I'll keep you posted what happens.
4marine 8)
