I just bought a atc 200 and it fires right up and idles great untill you get about half throttle and then it just bogs down and will die if you don't let off it will rev up in netural but not any gear any ideas? I've cleaned the carb 3 times and set the timing it will also run good if the choke is on but won't idle
