Results 46 to 59 of 59
Thread: 2004 300EX quad to trike conversion.
  1. #46
    Kentucky
    2,294
    Great job John ! And out of curiosity have you considered swapping the forks around and trying a leading axle versus a trailing axle instead of adjusting the rake again ?
    Tionesta Trikes ATC 450R
    86 250R
    86 Tecate-3
    83 ATC 70
    85 Big Red
    81 KLT 200
    85 250SX
  2. #47
    Apr 2002
    s.w. michigan
    6,498
    Yes I did, but
    Not so much swapping forks around but simply turning them outwards. It should not effect the speedo set up I just got on there but defiantly I would loose the front brake,,,, I want to keep that.
    Swapping forks around I probably could keep front brake but would loose the correct direction on speedo drive gear that I just done a swap for. I want to keep that as well.
    Attached Thumbnails Attached Thumbnails 300ex speedo 3.jpg   300ex speedo 1.jpg
  3. #48
    May 2014
    NW Houston (Cypress)
    57
    Any chance of a video with you on trike? Would love to see how it handles.
    Awesome build.
  4. #49
    Apr 2002
    s.w. michigan
    6,498
    Quote Originally Posted by HoustonAE2 View Post
    Awesome build.
    Nope, no videos Allen. I was thinking early on in the build that this would be a good starting point and do suspension upgrades this winter.
    I am now leaning towards leaving suspension just the way it is. The cost of inverts on the front + something 600 dollarish rear shock just don't add up for the way I ride (slow),,, it basically rides and handles just fine as is,,, for me.
    Not to say suspension upgrade (if you want to say it that way) won't ever happen but not in the plans at this time.
    So yeah, if you come across a cracked up 300EX I highly recommend the conversion because it is a silly simple to do IMO.
  5. #50
    Great job Johnny! We'll see it in June!
    Nov 2007
    I can speak from riding with john, this trike looks to handle very well. That's handling overall from turning to bumps. Great conversion john, looks like a factory Atc going down the trail.
    Chris
  7. #52
    Apr 2002
    s.w. michigan
    6,498
    300 EX conversion update
    After many rides and about 300+ miles the front end felt a little loose on my last outing in Baldwin, mi. (the birthday ride).
    Front 250R forks needs new seals so while the outside weather is still tolerable I decided to investigate.
    What I found was the hard point area for the EX steering shaft bracket has the 4 nuts welded on the inside and they broke free. I had to cut the plate with grinder cause the oem nuts was just spinning They didn't pull thru the thin plate and my 2 additional hardened nuts + bolts I had installed all the way thru the frame kept it all together preventing a major accident.
    So now that I know this conversion set up (300ex) is definitely my daily rider I will refab and have the goose neck welded in place.
    Bottom line is if you are considering this quad for a conversion don't rely on the 4 bolt steering shaft mounting area for long term.
    More to come as this rather slow improvement comes together.
    john
  8. #53
    Apr 2002
    s.w. michigan
    6,498
    Ready for the weld shop
    This part of it went along better then I anticipated. Probably since I had the rake previously figured out I suppose.
    I used the angle of the inserts as my guide and cut away what I needed too from the lower frame tubes. Thankfully I did not need to cut away any of the factory welds + gussets.
    Lots of grinding on the C channel to get good fitment for the welder,,, LOTS of grinding.
    Oil drained, battery out, electrical stuff zip tied back out of harms way (and unhooked for the most part). I figure they will need to flip it on its back and sides to best get to the inside area for welding. All they will need to do is to remove the triple tree retainer nut and the front end will drop out and be out of their way.
    Attached Thumbnails Attached Thumbnails 300ex 9.jpg   300ex 6.jpg   300ex 5.jpg   300ex 7.jpg   300ex 4.jpg   300ex 1.jpg
  9. #54
    Jan 2014
    La
    1,062
    you have the rake just right now its starting to look like a proper factory built 3 wheeler.
  10. #55
    Crazyktmmatt is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2014
    Idaho
    237
    How did this turn out?
    200x - I think I have 7 of em?
    10 70's
    3 350x's
    Tri Z
    225
    kxt
    and the 90 110 125m that I need to get rid of.
    YT175 with rear suspension sold
    200es- SOLD !!!!!!
  11. #56
    Apr 2002
    s.w. michigan
    6,498
    Very well !
    I am very happy with it. It fits my trail riding requirements very well.
  12. #57
    Apr 2016
    Columbus, IN
    60
    reading the thread title i didnt have high hopes for this turning out well, but after reading through the whole thing it ended up amazing man, incredible work.
    "If you're gonna be dumb, you gotta be tough"
    ** 1986 Honda ATC 250SX - '86 250R forks - LED headlight - 250r gold wheels **
  13. #58
    camy is offline First Time Rider Arm chair racerNew to the board
    Sep 2008
    Quebec, Canada
    75
    wow that's some nice DIY!!! I really like the idea of taking a little reliable machine like this and take the low cost way instead of TPC 450r 7000 + $ machines
    Tomy ATC- my mother gave it!!!
    1985 ATC 250SX
    1985 ATC 200X
    1985 ATC 200X
    1985 ATC 200X - Bought from Yamada. Resto mod project
    1985 ATC 70 - Full resto... girlfriend's bike
    1984 ATC 70 - In restoration Lifan 120cc in project
    1983 ATC 70 - Full OEM yard beater!!!!
    1983 ATC 70 - Sold to Yamada who sold it
    1979 ATC 70 - Sold to Yamada
    1973 ATC 70 - 125cc ripper to be bring back to stock
    1985 TRI-ZINGER
    1984 ALT50E
    1983 ALT50D
  14. #59
    Apr 2002
    s.w. michigan
    6,498
    Thanks guys ! It is a real nice daily driver for me. Tinkering around with dash lay out today to better facilitate my new GPS mount.
