Results 31 to 45 of 51
Thread: 250sx dies after being held wide open
  1. #31
    Chopsaw is offline Just Too Addicted Arm chair racerJust too addicted
    May 2013
    St. Louis
    505
    Quote Originally Posted by beastybaconman View Post
    Thanks for the help, I don't have much money right now so I'll just get a rebuild kit. There is a brass thing there that I thought was a screw but it's flat. The previous owner must have snapped it off or something
    I had one that had no pilot screw . Was just a plug .
  2. #32
    Jan 2011
    Choctaw, OK
    2,755
    I've had them come through with no screw at all.
  3. #33
    Apr 2013
    Vermont
    67
    Just got the rebuild kit and put in a new screw. When I was putting it in I screwed it down until it got hard to turn and one of the ears broke off, so I figured that must be all the way down. I just put a little notch in it with a band saw and screwed it out 2 turns. Is the end supposed to stick out this far?
  4. #34
    Jan 2011
    Choctaw, OK
    2,755
    on the 85 carbs yes. The 86/87 carbs the screw goes in further.
  5. #35
    Apr 2013
    Vermont
    67
    Took it for a test drive and there wasn't any poping or backfireing when I let off the gas at first when I was taking it easy, but once I started to get on it a little more and run higher RPMs it started to backfire again. Right now the air screw is 2 turns out how should I adjust it to richen the mixtrue? or do I still just need a bigger slow jet?
  6. #36
    Jan 2011
    Choctaw, OK
    2,755
    Bigger slow jet. Fatten it up some. What does the plug look like?
  7. #37
    Jan 2011
    Choctaw, OK
    2,755
    Have to ask, when you replaced the carb parts, did you pop the needle jet out are put in the new one? That's the brass barrel the needle passes through?
  8. #38
    Apr 2013
    Vermont
    67
    Quote Originally Posted by Flyingw View Post
    Haven't pulled the plug yet I will tomorrow. All I did to the carb was easy-out the old air screw and put in a new one with the spring o-ring and washer.
  9. #39
    Apr 2013
    Vermont
    67
    Just pulled the plug, it looks alright.
  10. #40
    Jan 2011
    Choctaw, OK
    2,755
    Ok, not too bad. At least its not white.
  11. #41
    Apr 2013
    Vermont
    67
    It seems to be running pretty good I think half the reason it pops when I let off is because there's no packing in the muffler, but I'll try changing the slow jet. And I just figured out the exhaust is leaking where the head pipe is clamped into the muffler, is that a big deal or should I try to seal it?
  12. #42
    Jan 2011
    Choctaw, OK
    2,755
    THAT IS A BIG DEAL!!! That alone will cause the motor to run lean. I would suggest not running it until you get that fixed. Be very very careful when you loosen the nuts on the exhaust flange. The nuts love to fuse to the studs and when you go to break them loose, you run the risk of twisting the studs. Happens all the time. If you have access to a torch, heat those nuts and studs till they're red.
  13. #43
    Apr 2013
    Vermont
    67
    I'm just talking about where the two pipes connect with a clamp, not where it comes off the head
  14. #44
    Jan 2011
    Choctaw, OK
    2,755
    My bad!!!!! That's not so much of a big deal.
  15. #45
    Outlaw #24's Avatar
    May 2013
    Iowa
    364
    Not to be a Thread Dawg , But Beasty you need to learn something before you go any further ! Listen to these people that are responding to your questions! 1st, You have been told to repack the silencer (Muffler) or it won't run right ! 2nd , You said you didn't have anything except a nylon sock for a air filter ! Did you ever put a proper filter on it cause that will cause you problems is what you were told ? Before you do any jetting fix the obvious , such as header welded, Muffler packing, Filter element ! JMO but I hate hearing somebody give advice on hear and the people getting the advice not heeding what they have been told. Packing for the muffler is fiberglass insulation and pack the stuff into it , no matter how tight or loose it is packed is better than NO packing at all! BTW my wife's 250SeXy has the cobra exhaust and has a little popping at the end like you like ! Keep working on it and you will get it!
