I had a 110 Kawasaki when I was a kid, ran it into the ground. Bought some 4 wheelers but have always wanted another trike. Wanted the biggest one that still had the auto clutch, and found this 250sx. $640 bucks. Only started with kick start when I bought it, no power to the front switches, no headlight. I couldn't figure out why, found no power to the black wire under the headlight where it tees off. I ran a fused jumper from the battery to this site, and now the elec starter works and so does the headlight. I changed all the fluids, and taped up a rip in the swing arm boot, recently ordered a new one.
The suspension seems weak, I am 6'5" and 260 lbs, might be that or age. Can the rear spring tension be increased or swapped out? It is on the highest setting now.
After searching the board, I found I want to go with the 23 7 10 front tire on the 10x5 wheel, and 22 11 10 rear tires on 9 3+6 wheels.
What is the best front and rear tires for drifting? I have 4 wheelers for trails, want something to have fun with.
