Thread: 200X clutch seems to slip
    Aug 2014
    Thumb of Michigan
    6
    I have a pair of 200x trikes that both seem to have clutches that slip under hard throttle in any gear. My gut says they're probably going to need to be replaced. Anything to check before I year into them?
    Blossvale NY
    4,563
    Pretty much going to need clutch kits... Springs, discs, and steel plates should do it...
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Nov 2010
    Oshawa, On, Canada
    2,123
    I would recommend making sure your clutch lever has some play. If the cable is too tight it will cause it to slip.
    If the cable is fine, its clutch rebuild time
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Jan 2011
    Brazil, Indiana
    2,087
    Make sure your clutch lever is not adjusted too tight. Usually a clutch will slip in higher gears first when they start to go south.
    If you do have to replace them, I reccomended the Barnett dirt digger Kevlar clutch.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Apr 2014
    Edmond, KS
    2,591
    Always replace the springs when you replace your clutch like Ride-red said. I've read that they get weak over time and weak clutch springs can cause your clutch to slip. I'm not saying just replace your springs, I know some people who don't want to do the whole job.
