From what I can find the 200M basically has the ES rear end (except chain driven) and S front forks/fender. I think its still a 7/8" handlebar though.
My current handlebars are bent slightly and little rusted. Also I don't have a rear brake lever.
My plan is to put dirtbike handlebars on (with the pad), new grips, levers, maybe aftermarket thumb throttle and kill/light switch.
Have any of you put the dirtbike pad handlebars on an S or ES? I guess my main concern is the key and neutral light assembly thing and whether or not it will fit under the pad on most standard padded handlebars.
I am taller than most with long arms and legs so straighter handlebars may give me more knee room without a problem reaching the bars...
Also, can I buy most any universal brake levers and thumb throttle and connect the stock cables to them? Just like to know your thoughts and if you have done any of this.
Thanks guys!
