Results 1 to 15 of 19
Thread: Speedo help just picked up one
    Feb 2013
    Ontario
    812
    I bought a speedo off eBay for my 250sx. Looks like it's missing some wires and a broken nob. Anyone know what parts or who might be able to help? Came with a bracket and not sure for what machine. Any info would be greatClick image for larger version.
ID:	198439Click image for larger version.
ID:	198440Click image for larger version.
    Apr 2002
    s.w. michigan
    6,498
    Troy, the Mrs. makes those knobs. I will post up some pictures in a bit, on wrong computer now (no pictures of them on here).
    I think she likes to get about 12 dollars shipped stateside.
    Your missing wire is the lighting wire. Darn near any Honda motorcycle speedo/tach lighting works. Just a simple push in piece of rubber with bulb in it. I should have picture of that too.
    Now for the bad news, not a stinking clue what that bracket fits. Not sure if the ones we have available will work on SX or not ???
    Yep, I will post pics of those too
    john
    Feb 2013
    Ontario
    812
    Sweetness thanks John. Put me down for that nob. I will pay extra to have it shipped to me. Lighting good to know it's only a push pin style and I don't have to tear that bad boy apart. And for the bracket I have one on order from a kit off eBay with drive gear.
    The head I bought on eBay was listed as a trx speedo but clearly it's a ATC model.
    Thanks for all the info John
    Apr 2002
    s.w. michigan
    6,498
    Back light picture
    Here you go,,, http://www.3wheelerworld.com/showthr...59#post1324959
    In this Hondaline tach picture is the same push in rubber bulb holder you will need.
    Well I thought I had a better shot of the light bulb holder,,, it is the green + brown wire.
    Feb 2013
    Ontario
    812
    Excellent thanks for the quick pic.
    I will search eBay for one. When you say most Hondas will fit. What should be a easy fit the cb nighthawk models? Or just any two wire green and brown?
    Apr 2002
    s.w. michigan
    6,498
    I feel safe in recommending this for your lighting need
    http://www.ebay.com/itm/Honda-CMX250...f183b2&vxp=mtr
    Aug 2012
    Ct
    67
    John can you explain which wires you connect the harness to under the headlight?
    Thanks max
    Feb 2013
    Ontario
    812
    Ok I'm lost know. The pic I opened up on eBay showed a three wire with two bulbs. The speedo I have only takes one bulb from what I see. Just need to find the correct size that you insert into the speedo.
    Is the bulb a two pin twist style?
    Apr 2002
    s.w. michigan
    6,498
    I believe you will just use the larger angled one Troy. You will need to separate the 2 bulb/wires is all.
    PitBilly, you wire in sequence with the lighting wires. Either via a factory jumper harness or simply make your own.
    Feb 2013
    Ontario
    812
    Hey John
    I just bought one off eBay for 12.50Click image for larger version.
    Apr 2002
    s.w. michigan
    6,498
    Awe perfect , nice score !
    Aug 2012
    Ct
    67
    Hey john I found a honda speedo wiring sub harness for a trx300 year 87 and up
    The honda part is 08175-hc400-99
    Will this work for the 86 big red? Can't get link to ebay to work
    Thanks for any help
    Apr 2002
    s.w. michigan
    6,498
    I am not sure,,,,
    Feb 2013
    Ontario
    812
    Johns nobs are officially American made.
    Great work thanks guys!
    Apr 2002
    s.w. michigan
    6,498
    LOL ~ he said nob ,,,,
