I've got a nice 84 dx225. When I bought it, it ran rough and didn't want to idle. Noticed the muffler is gutted out and rust patched everywhere, also i installed a New pleated paper style airfilter.
It came with a yfm250 carb kit, they had already used the needle valve.
so I cleaned the carb and it ran better but would pop when decelerating in 4-5 gears.
So i installed the rest of the kit. I noticed the main jets were very similar in sizing, however the pilots were quite different sizes, the new pilots side holes were half the size.
I took the AFR screw to full in, then out 1-1/2 turns. It ran well, idled good and started with some persuasion(had to choke it at 80-85°f, I went riding Sunday. The 1/8 mile trail to the sand had been turned into a Mud drag pit practically, tore through it where 450r's and 2wd utilities were getting stuck.it did good till it had been riden for a hour or so and while traversing the mug on the trail back to the parking lot it started to break up/bog a tad when riding its upper rpm band in second.
Got back and changed the jets back out, starts eaiser and seems to rev higher, i set the afr at 1-1/4 turns out. But now it pops on decel again....carb is clean and clear so are the jets, no float issues that I can tell.
Any ideas guys? something I'm missing? I have an extra
