Thread: Long term 2 stroke storage
    Mar 2009
    halifax
    237
    I've got an 86atc250r motor I am going to be storing for 5 or so years. I was just wondering about the effects of long term storage. Specifically rust in the main bearings(will squirting oil in those 2 holes that go to the crank just inside the base gasket help).Also, will storing it without tranny oil kill the clutches and the other bearings, and will the waterpump seals ''dry out'' after time. The motor is stored in my house, but it is high humidity in Nova Scotia near the ocean.
    Any opinions,tips. Thanks
    Jan 2014
    Massachusetts USA
    782
    I keep my spare engines on a shelf in the basement, in bags to keep the dust off, but not sealed so as to trap moisture. They rest on a cheap $5 rubber boot tray in case one decides to seep any oil, and I spin them over now and then to redistribute oil. Storing the engine in your house should be fine. For what its worth, I read somewhere that conventional 2-cycle oil does a better job than synthetic oil at sticking to surfaces over long periods of sitting. I don't have any first hand experience to prove/disprove that, however. I do use cheap 2-cycle oil to coat the insides of my extra steel tanks on the shelf, seems to keep them from rusting.
    1985 Tri-Z 250
    1985 ATC250R
    Pacific NW
    4,255
    Quote Originally Posted by fordnut79@hotma View Post
    I just tried marine fogging oil. for gas tanks after I dried them to dust.
    Not sure about it yet but the name sure sounds right.
    Nov 2002
    Chezzetcook Nova Scotia
    1,838
    Hey Lawarence. Its a messy way but fill the engine with 2 stroke oil and rotate it till oil comes out of exhaust port. As far as 5 years oil in the crank case should be fine. Why are you storeing it for 5 years?
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Mar 2009
    halifax
    237
    Well its been stored in my house for 2yrs. Worse case scenario another 2 or 3yrs. Just a mint motor I'm hoarding so to speak.Click image for larger version.
    Nov 2002
    1,838
    Why store it? Cant find a good roller? It is in nice condition. Wish my tecate motors looked that great. I may be able to help you out with a 250r. Buddy says the motors blown.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
