Thread: 85 250sx differential compatabilty
    Aug 2004
    Gettysburg PA
    13
    Hello guys,
    first off wasn't sure whether to post this here or in the ebay forum, but im looking to buy a differential for my atc and found a pretty nice looking one on ebay. Its listed as an 87 trx250 rear end but also has others, including 85sx in the title so I just wanted to double check and see if these were compatible or if the seller is just trying to get more hits. thanks! heres a link
    http://www.ebay.com/itm/1987-TRX250-...f51987&vxp=mtr
    Dec 2007
    Quebec,Canada
    1,014
    will fit no problem
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Aug 2004
    Gettysburg PA
    13
    thanks atc500x!!
    didn't wana blow all that money and not have it fit!
    Jan 2011
    Choctaw, OK
    2,755
    The TRX diff is the same gearing as the ES. The SX gearing is unique to only the SX. The ES/TRX ring gear is one tooth larger so you will loose a little top end but gain torque on the bottom end.
    Apr 2012
    USA
    4,133
    My cousin has a 250sx with a big red 250es rear end, that thing is a crazy wheelie machine vs my stock 250sx. I don't think he loss much top end speed, but he gets there a a bit quicker than me. probably top speed of ~52mph vs mine at 55mph.
