My 86 250sx came with the forks on backwards, drum on the opposite side, not sure why, maybe to increase the wheelbase. Today, I put new wheel bearings on, and swapped the forks back to the way they should be. I torqued the axle to spec but left the fork tubes loose. The right fork was out to where the nut is on the axle-the top of the nut was flush with the fork. The pic in the manual shows the head of the axle nut sticking out enough so a socket will fit completely on it when everything is assembled, so that's how I did it, but had to really push it in to get it there. Then I torqued the 4 bolt rh side cap to axle, and the fork tubes per the manual. Now the front wheel looks crooked, and at idle speed it is wandering all over, won't steer straight.
What should I do?
It rode fine before messing with it. I recall that the axle nut was partially covered by the 4 bolt clamp when I began disassembling it.
The bearings weren't shot, I figured I would change them while swapping the forks over and checking the brakes. I also put a new wheel tire combo on. The 23 7 10 on a 5 inch wheel. The wheel spins true.
