Results 1 to 8 of 8
Thread: Breaking in 85 Tecate, got some questions???
    Apr 2012
    Osceola,Missouri
    95
    Alright be easy on me here these questions might sound dumb so here we go. I rebuilt my tecate and have a tank of gas through it and have started really getting on it. Is it normal for it to rev out rediculously fast? Like if i put it wide open in 1-3 it immediately just spins the tires and revs out. It is really really low geared. The sprocket sizes are 13/42 which i think is stock and im running 22 11 10 fast trekkers. Its hard to explain over the internet but my old 86 250r just pulled through the gears, it seems like this tecate just revs out so fast. The clutch is definately not slipping. Im thinking its a gearing issue but wanting to ask people who have rode other tecates(this is my first one).
    9,019
    Check your plug, as long as it's not white you should be good. Try driving it on pavement to see if it still revs out that fast when it's not spinning.
    Jun 2009
    Leander TX
    2,217
    With knobbies, my current Tecate spins through all 5 gears. Not with paddles.
    The green one I sold spun any tire anywhere. I have seller's remorse about that one.
    Sep 2005
    MICHIGAN
    2,027
    I think he means the gearing is really steep and it tops out really fast. My impression of my 86 and my 84 I had was that you hit 5th gear in no time and you would keep on shifting hoping for more but there was none left. You get there real fast but it only feels like you are going 55-60 MPH. And you probably are.
    I had a KX250 motor in my 84 though and I think my 86 has a KX250 motor in it now too. The gearing is even steeper in those. The primary gear and clutch basket gear have a different number of teeth and the trans gears are slightly different too. Is your exhaust port split (KX250 top end)?
    1st gear is so steep and short that to me it was completely a waste of time to use it if you were just going to launch and haul ass.
    13/42 gearing is quite appropriate for 22 inch tires.
    86 T3
    84 T3
    86 KX250
    Apr 2012
    Osceola,Missouri
    95
    On pavement and on the low end of any gear 1-5, if i blip the throttle to full it will stand straight up. I have rode lots of air/liquid 250r so im familiar with riding 2 stroke three wheelers but this thing has more torque than my 350x lol. The top end does not have a exhaust bridge.
    Sep 2005
    MICHIGAN
    2,027
    I think I used 13/40 gearing on mine with the stock 22" and cold cutter ice screws. I didnt ride it on pavement and the throttle, but it still did wheelies on the ice and snow.
    Check out my parts that swap thread as there are a ton of rear sprocket options using polaris part numbers.
    http://www.3wheelerworld.com/showthr...ap-Interchange
    Sprockets for rear 1984/85 Tecates:
    JTsprockets.com
    JTR 478
    Available teeth numbers in: 38, 42, 45, 43
    You can also use:
    JTR 1478: 30, 34, 36, 38, 40, 42, 43
    This sprocket is also available in alloy:
    JTA 478: 40, 41, 42, 43, 44, 45, 46, 47
    JT
    Rear Sprocket
    38-tooth
    520-Chain
    Fits: Polaris
    2x4 300 1994-95
    2x4 400L 1994-95
    4x4 300 1994-95
    4x4 400L 1994
    Big Boss 250 4x6 1989-92
    Big Boss 250 6x6 1991-93
    Big Boss 300 6x6 1994
    Big Boss 350L 6x6 1993
    Big Boss 400L 6x6 1994-97
    Big Boss 500 6x6 1998-99
    Cyclone 250X 1987
    Magnum 425 2x4 1995-98
    Magnum 425 4x4 1995-98
    Magnum 6x6 1996-97
    Scrambler 250 1985-86
    Scrambler 400 2x4 2000-02
    Scrambler 400 4x4 1995-2002
    Scrambler 500 2x4 2001-02
    Scrambler 500 4x4 1996-2006
    Scrambler 500 4x4 Freedom 2002
    Scrambler 500 X 2001
    Sport 400L 1994-97
    Sportsman 350 4x4 1993
    Sportsman 400 4x4 1994-96
    Sportsman 500 6x6 2000-04
    Trail Blazer 250 1990-2006
    Trail Blazer 250 ES 1996-98
    Trail Blazer 400 2003
    Trail Boss 250 1985-99
    Trail Boss 250 2x4 1985-99
    Trail Boss 250 4x4 1987-92
    Trail Boss 250R/ES 1987-89
    Trail Boss 325 2000-03
    Trail Boss 330 2003-06
    Trail Boss 350L 2x4 1990-92
    Trail Boss 350L 4x4 1990-92
    Xplorer 250 4x4 2000-02
    Xplorer 300 4x4 1996-99
    Xplorer 400 4x4 1995-2002
    Xpress 300 1996-99
    Xpress 400L 1996-97
    86 T3
    84 T3
    86 KX250
    Apr 2012
    Osceola,Missouri
    95
    That thread is awesome, I have a junk 425 magnum out back that i would have never guessed would fit. its got a 38 that im gonna try.
    9,019
    Quote Originally Posted by 3wheeledfanatic View Post
    Now you're just bragging!
