Results 1 to 2 of 2
Thread: 81 ATC250r Clutch Question
    renotrikeguy's Avatar
    renotrikeguy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Reno,Nevada
    433
    When I first start my bike, and shift into first gear the whole bike lurches forward. This is even with the clutch lever all the way in.
    The clutch cable doesn't have much more room for adjustment either.
    So do you think it would be time for a new clutch to be installed? And if so what should I change out, just the friction discs and clutch plates?
    I know someone has to have the answer..
    Thanks in advance....
    Chris
    Chris (Reno,Nevada.)
    67 Honda CT-90
    75 Honda ST-90
    81 Honda 250r
    85 Honda 250es BigRed
    99 Honda XR250R
    04 Honda CRF150F - Cousins Ride
    Front royal, va
    2,186
    sounds to me like you might have to pull the clutch cover and adjust the 10mm. nut on the pressure plate,thats what i had to do on my banshee,could be different on yours
