Results 1 to 7 of 7
Thread: 85 250R rear axle carrier rubbing problem
    May 2011
    The Granite State
    914
    this is about an 85 250R. anybody ever have this happen. I have an 85 swinger. 85 only lonestar carrier, and 85 durablue axle. As you can see the sprocket hub was rubbing on the carrier. it only rubbed a bit then sheared the alum. and now spins free and will work but still kinda pissed me off. I had this same axle in an oem carrier before with no spacing issues.
    Also this lonestar carrier you have to spin up towards the grab bar to tighten the chain, I thought I remembered spinning the oem carrier down towards the ground to tighten the chain ???
ID:	199393Click image for larger version.
ID:	199394Click image for larger version.
ID:	199395Click image for larger version.
ID:	199396Click image for larger version.
    86 350X ::: 85 250R
    Projects
    350x
    Come and Gone
    86 350x : 84 250r X2
    85 350x X2 : 84 200es X3
    83 200e : 78 ATC90
    May 2011
    The Granite State
    914
    at least I think its a durablue axle
    86 350X ::: 85 250R
    Projects
    350x
    Come and Gone
    83 200e : 78 ATC90
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,244
    so the carrier works like a cam shaft.. spin it around and it will reverse the direction needed to adjust the chain,
    May 2011
    The Granite State
    914
    right but then the holes you put the adjusting tool in to spin it are on the backside (inside facing forward into the trike), maybe they somehow drilled the holes on the wrong side?
    86 350X ::: 85 250R
    Projects
    350x
    Come and Gone
    83 200e : 78 ATC90
    na
    5,702
    I have a RPM axle in an 86 carrier that was "going" to rub but I caught it on assembly. What I did was take the old center tube from a stock axle and chopsawed a 1/16th collar and butted it to the left side axle journal to shim the axle over just enough to clear it. It did not effect chain alignment and has been fine for over 4 years.
    Other things to consider is the center axle tube in your carrier may not be wide enough to space the bearings properly from the factory, or it was a dual row carrier bearing set-up that someone mistakenly installed single row carrier bearings. I would call the carrier company that built it and question them if it was brand new.
    Proudly NOT a member of
    "Team on the Teat"
    250rAL is offline Just Too Addicted Arm chair racerJust too addicted
    Sabula,IA
    620
    I have the exact same combination of parts and mine did the same thing. I just machined off some of the sprocket hub with a Dremel.
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
    Poco Loco's Avatar
    May 2013
    Clap Saddle California
    389
    Yep I had the same problem I had to clearance the carrier with a flapper wheel. The durablue sprocket hubs are thicker than oem. I run a durablue also.
    Shart Guard .......Use it !
    Pink Powerwheels Barbie trike
    1985 Crash and Burn champ
