Hi all, I have an 85 200m I purchased with a donor bike. The donar ran great but no brakes or plastic. The other bike would start but not run past idle, and was leaking oil so I replaced the engine, coil, battery and carb from the running doner bike. I'm STILL having the same issue. Starts first pull with no choke idles perfect. Touch the gas slow and it will begin to climb rpm then about mid range it sputters and zero power. Won't move the bike. Hit it fast and it stalls. I've cleaned the carb to immaculate shape, new fuel and lines. Plugs good. The only thing that I didn't swap from the other frame was the little black box that has a connector with five or six wires. Could this be it? It has a different harness is why I havnt as the donor was an 84 and the plugs are different. Any help?
