I bought my 86 Tri-z a few years ago, I was told that it had a fresh top end, but a couple months after buying it, I lost all compression. I can push the kick start down with my hand without any problems. Recently, I pulled the jug off and found that I had apparently melted the piston and rings. The cylinder is not badly scored, and I would like to have it repaired and plated. My problem is that I don't know if the previous owner had the jug bored and sleeved. I had read that if it was sleeved, I can't have it plated. I attached a few picture of the piston and the cylinder, and I am hoping that someone may be able to identify whether or not the cylinder is stock or if a sleeve has been put in. Any advice or insight would be greatly appreciated.
