It's gotten a little colder out around here, and the other night, my tri-z started acting up. It ran really good, till you got up around 1/2tofull throttle (not exactly sure at what throttle opening), but when you went past it, the engine would die out, unless you took it back under half throttle,then it runs really good. If you gradually increased the throttle, it would keep running, but it would still cut out at some point. My question is, is this happening because it's running lean, or is it running rich from the colder air hitting the radiators? Off idle, it smoke like a mother till it remotley warms up,(but that is probably normal), the only mod is a k&n airfilter(in the stock airbox), and the previous owner said that the main jet was upped a couple sizes,could it be too rich, or lean, how can I tell? I cant do a plug chop (no kill switch).
SOON MY PRECIOUS!
