Thread: atc 200x front rims Help please
    Aug 2014
    Quebec
    51
    Why so difficult to find a front rim +hub+ axle like the 200x 86 87 or same .no aftermarket wheel.?And what is the stock size and bolt pattern...offset or centerline for front rim?THANKS
    6,811
    If you don't have a show queen just purchase a 83-85 200x set up , it will bolt up with no issues just the same .
    Quote Originally Posted by freak trike View Post
    Aug 2014
    Quebec
    51
    you right ...now i check for that...200x 83-85 front hub and axle assembly. do you know the spec of the axle ..lenght and diameter.?
    6,811
    Like I said its the same even the axle . Also the 83/84 250r is the same set up as well axle included only difference is its gold ....
    [/I]
    Williamstown PA
    5,825
    86-87 200x front wheel is the same as 85-86 atc250r just gold. I'd buy a 10" front wheel and have better tire options personal. everything swaps out with these bikes.
    Jun 2014
    indiana
    31
    Are the 10 inch wheela available often on here?
    Slidell, LA
    4,738
    Quote Originally Posted by 08rap View Post
    There's a group buy going on right now.
    http://www.3wheelerworld.com/showthr...light=10+wheel
