Results 1 to 12 of 12
Thread: 200x poping in high rpms wont gain speed?? need help!!!
    jason200x is offline At The Back Of The Pack Arm chair racerFirst time rider
    when i rev it up or when in hgh rpms when rideing it wont go full speed in any gear b/c ti pops but only in mid to high rpms?
    could this be the fuel to ait mixture screw or doe sit need a jet
    b/c it has pipe k&n and engien mods?
    im not shure if it has been jetted so could soem oen tell me how to check?
    Ashland City, TN
    2,576
    Sounds like your main jet is reallllly lean to me. Pull the plug and see what color it is.
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    what should i look for on the plug if its lean? and what shoudl i look for if its right?
    Shrewsbury, West Virginia
    564
    Start your machine up, let it get up to operating temp. and then take it as fast as you can go, hit the kill switch to shut the engine off, but keep the throttle wide open and in gear until it rolls to a complete stop. (By the way, take a spark plug wrench with you) Pull the plug out. If its white, you're too lean and need to raise the jet size in small increments. If the plug is black, you're too rich and need to lower the jet size. Repeat this process with the new jets until you find the right one.
    Justin ~hondaATCman~
    '82 Honda ATC 110
    '81 Honda ATC 250r (Summer Project)
    '87 Suzuki LT 250r Quadracer - Very Modded...FAST!!
    '03 Yamaha Big Bear 400 4x4
    '85 Ford Bronco II 4x4 2.8 V6
    Rittman, Ohio
    6,276
    If its popping and spitting and sputtering at higher RPMs, which is what I think you were trying to say, its doubtful to me its a carburetion problem, and more likely electrical. Start with a fresh plug, which you should do before beginning the plug reading procedure anyways.
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    Yeah, I had an 86 250sx, that would do that, and I could never figure it out, checked carb, timing, electrical, and it turned out to be just the sparkplug, go figure. Start with the little stuff first, you will thank yourself in the long run.
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    i rebuklt the carb did timeign and new plug, btu when i got the engien theplug i pulled was back soo ill go try right now
    ok i ddi wha you guys said , waterpumper said i need to take my air box of and i forgot to put this pice in to the carb wehn i rebuilt it he said that could be soem of the problem, and he also said to raise or lower the needle that goes in the center of the slide, also to saok the cabr ove night in a bowl of carb cleaner and the blow it out with compressed air or a air compresser, if its electrical should i start by replaceing the plug wire, and if that dont work then what? what are the specs to test to see if im getting enough spark?
    speed20 is offline Check my feedback before buying from me Arm chair racerJust too addicted
    Jun 2002
    OH-IO
    816
    ive had problems like this on my 200x's....It could be a ton of things, bad connection, carb, timing, cdi timing (advanced or retarded). Could also be a sign that your Stator is going out too.....Stators are common (for me anyway)!
    ok i got it fixed theres a little ball on the choke lever that locks into a little hole it wasnt completely locking in so it was hitting the choke lever and it was going into choke and wanting to kil its self by closing the chok so it wasnt getting enoguh air, just wanted to let you guys its fixed and runs good now
    May 2002
    610
    That happened to mine also. took a little file and fixed it up.
    Sam from Florida
    1985 BIGRED $ 200X
    theres a little meteal piece that just nedd to be bent so that it was harder for the choke lever to move therefore holding it there harder
